kimbiel's avatar
kimbiel
Can I swap disks between two ReadyNAS Pro 6 units.
One of my old ReadyNAS Pro 6 units died on me. It is totally unresponsive - I think that the powersupply died. I have 6x4 Tb of data which I need to save. I have an identical second unit which is wor...
  • Marc_V's avatar
    Sep 16, 2020
    kimbiel
    Welcome to the Community!
    Your plan should be okay specially if you have drives to spare using on the RN528X to be initialized. You can then replace the drives of your working Pro 6 with drives of the one that died and be able to boot it normally  provided that  both are using the default OS4.2
    You can also follow the procedure on ,igrating disk from 4.2 to OS6 if you want but IMO your plan would be fine.
    https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86
    HTH
ProSupport for Business
