M4RM
Nov 14, 2018Aspirant
Can not connect to ReadyNAS via Browser(s) SSL CIPHER errors
Please Advise, I can not connect to ReadyNAS units from browsers, SSL error.
This started this morning, as I could connect fine yesterday.
Work arounds tried:
When I put in http adress, co...
- Nov 25, 2018
I had the exact same issue as you have and tried similar things. Worth checking your antivirus. I've got Bitdefender, and it is causing the problem.
Under online threat prevention, there is a toggle for 'Encrypted Web Scan' flick that off and I was able to access as normal. I tried adding the address as an exception in Bitdefender but that didn't work.
Either way it would be nice if Netgear recognised that when Antivirus and browsers are all considering their remote access solution is unsafe it is probably a hint that they need to update things.
M4RM
Firmware:
ReadyNAS 2304: v6.9.4(all units same version)
ReadtNAS 314: v6.9.4(all units same version)
Ultra2: v4.2.21, v4.2.21, v4.2.30
M4RM
No change with additional steps:
Cleared browser cache(s)
cleared microsoft SSL state
Added as trusted site(s)
Cleared DNS (ipconfig /flushdns)
Excluded ipaddresses in antivirus
