M4RM
Nov 14, 2018Aspirant
Can not connect to ReadyNAS via Browser(s) SSL CIPHER errors
Please Advise, I can not connect to ReadyNAS units from browsers, SSL error.
This started this morning, as I could connect fine yesterday.
Work arounds tried:
When I put in http adress, co...
- Nov 25, 2018
I had the exact same issue as you have and tried similar things. Worth checking your antivirus. I've got Bitdefender, and it is causing the problem.
Under online threat prevention, there is a toggle for 'Encrypted Web Scan' flick that off and I was able to access as normal. I tried adding the address as an exception in Bitdefender but that didn't work.
Either way it would be nice if Netgear recognised that when Antivirus and browsers are all considering their remote access solution is unsafe it is probably a hint that they need to update things.
Nov 14, 2018Guru - Experienced User
M4RM wrote:
Internet Explorer 11 version 11.0.9600.19155 64-bit
Turn on TLS 1.0, TLS 1.1, and TLS 1.2 in Advanced settings and try connecting to https://192.168.1.28 again.
Did you try this?
- M4RMNov 14, 2018Aspirant
whoops, I missed listing this, that was one of the first thing I tried in IE - checked all 3 TLS
- StephenBNov 15, 2018Guru - Experienced User
This seems odd to me, since I am not seeing this issue with any of my NAS (OS-6, OS 4.2, OS 4.1). I am also running Chrome Version 70.0.3538.102. The OS is Windows 10. My RN526 is running 6.9.3.
The Chrome security panel says
Connection - secure (strong TLS 1.2)The connection to this site is encrypted and authenticated using TLS 1.2 (a strong protocol), ECDHE_RSA with P-256 (a strong key exchange), and AES_128_GCM (a strong cipher)The certificate is self-signed, so it is not trusted.
- DavidBushNov 20, 2018Aspirant
I seem to have exactly the samne problem - did you find a fix?
