M4RM
Nov 14, 2018Aspirant
Can not connect to ReadyNAS via Browser(s) SSL CIPHER errors
Please Advise, I can not connect to ReadyNAS units from browsers, SSL error.
This started this morning, as I could connect fine yesterday.
Work arounds tried:
When I put in http adress, co...
- Nov 25, 2018
I had the exact same issue as you have and tried similar things. Worth checking your antivirus. I've got Bitdefender, and it is causing the problem.
Under online threat prevention, there is a toggle for 'Encrypted Web Scan' flick that off and I was able to access as normal. I tried adding the address as an exception in Bitdefender but that didn't work.
Either way it would be nice if Netgear recognised that when Antivirus and browsers are all considering their remote access solution is unsafe it is probably a hint that they need to update things.
TikTok90
Nov 25, 2018Star
Padg_UK
Nov 29, 2018Initiate
Many thanks for your help re Bitdefender and accessing my NAS drive.
Much appreciated.
