POrterhouse
Aug 14, 2011Aspirant
Can not get Time Machine to work off wireless
I tried to get time machine to work over my wireless but it only seems to work when it is hard wired. I am using a macbook air 13 inch. Does anyone have suggestions?
POrterhouse
Aug 17, 2011Aspirant
I have followed your solution and switched the dir-665 to multicast mode and that made it so I could not connect to the internet at all. I put the setting back. I did notice running my bootcamp partition Windows 7 (not using VMware) I saw a Netgear access point along with my dir-665. I changed all the channels on my dir-665 to see if i could get that Netgear access point which is not mine to drop and I could not get rid of it. I am still back to the drawing board not being able to use Time Machine over my wireless connection. I appreciate all your help. Do you have any more suggestions? i really want this to work correctly.
Porterhouse
Porterhouse
