JMehring
Sep 29, 2013Apprentice
Can 'Recycle Bin' be enabled for CIFS and OS 6.1.2 on a 314?
The older 4.x version of the OS allowed a Recycle Bin when using CIFS. Is this possible on the new OS 6.1.2? I noticed a recycle.conf file in '/data/._share/media' containing: 25000,0
SuperNASman
Aug 04, 2015Aspirant
Is there any updated information about enabling Recycle Bin on OS 6? Specifically OS 6.2.4 on a ReadyNAS Pro 2.
What the hell kind of developer thinks it is a good idea to remove useful functionality in exchange for less useful functionality?
I can't choose when snapshots are taken, I can't take multiple combinations of Snapshots like Hourly and Weekly, and Snapshots provide much less protection against accidently deleted files than the Recycle Bin does.
I just wanted to see if there is any new guide or information on enabling Recycle Bin on OS 6.
- mdgm-ntgrAug 04, 2015NETGEAR Employee Retired
You can use SSH to enable it as described earlier in the thread.
Snapshots make much more efficient use of space than a recycle bin and unlike with a cifs recycle bin with snapshots you can delete files using whichever protocol you want.
Seeing you have a Pro 2, you could backup your data and downgrade back to OS4: https://community.netgear.com/t5/Community-Add-ons/Downgrade-to-RAIDiator-x86-from-ReadyNAS-OS-notsupported/td-p/859412
