PerBKWine
Apr 23, 2014Tutor
Cannot access USB disk; nwk password required
I have had a possible disk failure on a hard disk attached to the Netgear Readynas server. After having swapped the possibly failing HD with a new one I can no longer access the USB drive. If I try...
Apr 23, 2014Guru - Experienced User
- is "guest access" checked for the new drive?
-Did you also change the group to "nogroup"? when you changed to owner?
-After you changed the owner/group of the share, did you also check the "Set ownership and permission" box and click apply?
