PerBKWine
Apr 23, 2014Tutor
Cannot access USB disk; nwk password required
I have had a possible disk failure on a hard disk attached to the Netgear Readynas server. After having swapped the possibly failing HD with a new one I can no longer access the USB drive. If I try...
Apr 23, 2014Guru - Experienced User
Its in the "Share Access Restrictions" section on the CIFS tab.
PerBKWine wrote:
- is "guest access" checked for the new drive?
What do you mean? Where is that configuration?
I can't find any such parameter in Volume or Shares settings.
