PerBKWine
Apr 23, 2014Tutor
Cannot access USB disk; nwk password required
I have had a possible disk failure on a hard disk attached to the Netgear Readynas server. After having swapped the possibly failing HD with a new one I can no longer access the USB drive. If I try...
Apr 24, 2014Guru - Experienced User
What firmware are you running on the NAS?
What is the security mode configured as (user or share)?
