PerBKWine
Apr 23, 2014Tutor
Cannot access USB disk; nwk password required
I have had a possible disk failure on a hard disk attached to the Netgear Readynas server. After having swapped the possibly failing HD with a new one I can no longer access the USB drive. If I try...
Apr 24, 2014Guru - Experienced User
Other folks who use share mode also reported that they need to set a password on a new share and then clear it. Mine is set up for user mode, so it didn't immediately occur to me.
Certainly its a Raidiator bug, but since Netgear has phased out the share security mode it won't be fixed.
- KFjrOct 16, 2015Aspirant
I spent hours looking for the solution. I had previously had drives working and then updated them.
Many thanks!!!!
Such an easy fix.
