jtnn60
Mar 17, 2020Aspirant
Cannot perform a remote shutdown of a ReadyNAS using shell script and CURL
Based on various previous forum posts, I have developed the following shell script to use CURL to shutdown my ReadyNAS. I read about the need to add a csrfpId token due to a previous security fix to...
- Mar 22, 2020
I wrote up exactly how to perform remote shutdown of a ReadyNAS here:
Mar 18, 2020Guru - Experienced User
Did you try using https in your script instead of http?
jtnn60
Mar 20, 2020Aspirant
StephenB wrote:Did you try using https in your script instead of http?
Of course! I get the same error in both situations.
- StephenBMar 20, 2020Guru - Experienced User
One option is install sshpass and switch to ssh - using rnutil rn_shutdown to do what you want. You'd of course need to enable ssh
# sshpass -f <(printf '%s\n' nas-admin-password) ssh root@nas-ip-address rnutil rn_shutdownNote I haven't tested the above command (though ssh root@nas-ip-address rnutil rn_shutdown definely works if you type in the password.
