boolean_chants
May 29, 2014Aspirant
Can't access NAS - password fail - and not showing up on TV
Hi all, Firstly, thanks for any help you might be able to give me. Mods - please move this if it needs to be in a different forum, I looked, but I couldn't work out which it needed to be in, it d...
May 29, 2014Guru - Experienced User
Did you try "admin" as the username, and the NAS admin password?
What firmware are you running on the ultra?
BTW, it is odd that the network status is "offline". Do you see many errors when you click the "show errors" button? Also, do you only have 1 ethernet cable connected to the ultra?
