boolean_chants
May 29, 2014Aspirant
Can't access NAS - password fail - and not showing up on TV
Hi all, Firstly, thanks for any help you might be able to give me. Mods - please move this if it needs to be in a different forum, I looked, but I couldn't work out which it needed to be in, it d...
boolean_chants
Hi Stephen,
Thanks for your reply :)
I did try admin/NAS-password, it didn't work :(
Just in case I did it wrong - I clicked on 'Use another account' and typed 'admin' in as the username, then the correct password in - and it still comes up 'access denied'.
The 'Show errors' say this:
The first port says: "Offline"
Network Errors [Ethernet 1]
TX packets 0
TX errors 0
TX dropped 0
TX overruns 0
TX carrier 0
RX packets 0
RX errors 0
RX dropped 0
RX overruns 0
RX frame 0
Collisions 0
The second port says: "Online/1Gbit/Full-Duplex"
Network Errors [Ethernet 2]
TX packets 18572
TX errors 0
TX dropped 0
TX overruns 0
TX carrier 0
RX packets 48604
RX errors 0
RX dropped 15
RX overruns 0
RX frame 0
Collisions 0
Does it matter that I have port 2 with the cable instead of port 1? I can get my daughter to get in there and swap it over if needed...
There IS only one cable connected to the Ultra, should I have two???
I'm sorry, I'm not sure how to check the firmware, I checked the manual, but I can't see how to check it. :(
When I try to log in via the 'mystora' page, it just says 'Stora is offline'.
The firmware will, however, be the same as was bought with the machine, it's basically been unused since I bought it so I haven't had it connected enough to update the firmware.
Thanks again,
Larysa.
PS: I have another question about RAID - can I ask it here, or would you prefer if I started a new thread?
TX packets 0
TX errors 0
TX dropped 0
TX overruns 0
TX carrier 0
RX packets 0
RX errors 0
RX dropped 0
RX overruns 0
RX frame 0
Collisions 0
TX packets 18572
TX errors 0
TX dropped 0
TX overruns 0
TX carrier 0
RX packets 48604
RX errors 0
RX dropped 15
RX overruns 0
RX frame 0
Collisions 0
Thanks again,
Larysa.
