boolean_chants
May 29, 2014Aspirant
Can't access NAS - password fail - and not showing up on TV
Hi all, Firstly, thanks for any help you might be able to give me. Mods - please move this if it needs to be in a different forum, I looked, but I couldn't work out which it needed to be in, it d...
May 29, 2014Guru - Experienced User
Using port 2 is fine, and I am not seeing any issues with the ethernet connection.
If you log into the admin page of the NAS, you will see the firmware on the home page (about half way down). Right below the serial number.
Also, if you look on the security mode page (click on security on the left), is the NAS set to "user" security mode?
On RAID, a new thread is probably less confusing, but you can ask on this one if you like.
