boolean_chants
May 29, 2014Aspirant
Can't access NAS - password fail - and not showing up on TV
Hi all, Firstly, thanks for any help you might be able to give me. Mods - please move this if it needs to be in a different forum, I looked, but I couldn't work out which it needed to be in, it d...
boolean_chants
May 30, 2014Aspirant
Geez, you’d think by now I’d know to write long replies in word in case I lose them, but no… After over 15 years on forums, alas, I still get caught, so, after the big long reply I wrote – and lost - here’s a shortened version.. Grrr…
Firstly, thanks, again, Stephen, for your help.
The firmware is version 4.2.24… Probably about 5 updates behind, lol.
There’s nothing on the security ‘page’ – when I click on ‘security’ in the left menu, nothing happens, but there are two sections under the drop down – “Admin Password” and “User&Group Accounts”. Nothing under the Admin Password that seems to fit the question, and under the User Accounts it says “User accounts not found”.
With regard to RAID… I think I have a basic understanding of how it works (although my understanding may be VERY basic! Lol)
I *think* what I want is Raid-0 but I wanted to check whether I was right, and, how I change things if I am…
Currently it says:
Configuration: RAID Level X-RAID2, 2 disks
Status: Redundant
I currently have two 2.5Tb drives in the NAS, and I (obviously) want to add more lately…
I don’t need redundancy or mirroring because I have alternate backup facility, I simply want to use the NAS as a server for TV and movies.
I think it is RAID-0 I need because I want it to all show up as one drive on my windows explorer.
I am, however, wondering whether I should have them as JBOD because I’m concerned that, as I understand it, if they are RAID-0 and one of the drives drops dead, they are all unusable.
So – I currently have 5Tb in there, the next step is to add two more 3Tb, then next year, when I can afford it, another two 3Tb drives. This way, in the end, I’ll have 17Tb in there. That should be enough to keep me out of mischief for a while… (Incidentally, I can’t remember who, but, someone told me it’s best to add the drives in pairs, is that correct???)
Anyway, so, thanks again for your advice, I hope all of the above makes sense.
B_C
Currently it says:
Status: Redundant
B_C
