boolean_chants
May 29, 2014Aspirant
Can't access NAS - password fail - and not showing up on TV
Hi all, Firstly, thanks for any help you might be able to give me. Mods - please move this if it needs to be in a different forum, I looked, but I couldn't work out which it needed to be in, it d...
Jun 22, 2014Guru - Experienced User
2x3TB + 2x2.5 TB would give you ~8 TB of storage (7.27 TiB reported in Frontview). (the rule is to sum the drives, and subtract the largest). If you do a reset now (which will destroy the data, so you will need to restore from backup) you will be able to expand to 6x3TB later on - (~15 TB of storage, or 13.6 TiB reported in frontview).
