Munber54
Jan 23, 2021Aspirant
can't access ReadyNas Pro 6 because it's still using SMBv1
Hi. I have 2 ReadyNas Pro 6. but I can't access them because they are still using SMBv1. Looks like my model number is ReadyNASRNDP6000v2. When i open RAIDar and click on "about" it says my RAIDar ve...
- Jan 26, 2021
The best approach is to convert the Pro-6 systems to run OS-6 firmware. Then you'd have SMB 3 (as well as other features). Netgear doesn't support this (meaning that paid support wouldn't be available to you after the conversion). But many here have done the conversion. It is destructive, so you would need to have a full backup of your NAS. We can provide more detailed instructions if that is the path you choose.
As far as Windows 10 goes, it is easy to enable the SMB 1 client - just go into "turn windows features on or off".
Jan 26, 2021Guru - Experienced User
