MrLondon
Oct 16, 2017Aspirant
Can't connect to admin page
Hello unable to connect to my admin page, tried 3 different browers and restarting, i get as far as the login page. any ideas?
Oct 16, 2017Guru - Experienced User
Do you know what firmware you are running? Was there something that triggered this?
MrLondon
Oct 17, 2017Aspirant
6.7.5
cant think of any reason, just went to login and found i couldnt,
can still see the contents of the drive vis the finder.
- StephenBOct 17, 2017Guru - Experienced User
Does https://nas-ip-address/fwbroker respond? Use the real NAS IP address of course.
- MrLondonOct 17, 2017Aspirant
could connect and posted image of result.
Good.
Usually this problem is related to an app incompatibility - do you know what apps you had installed?
There are some fixes to get the admin ui back in 6.8.1, but there are some additional fixes in 6.9.0-RC1.
I suggest trying to manually install 6.9.0-RC1 using this interface, but if you are uncomfortable with beta firmware you can try 6.8.1 instead.
