MrLondon
Oct 16, 2017Aspirant
Can't connect to admin page
Hello unable to connect to my admin page, tried 3 different browers and restarting, i get as far as the login page. any ideas?
MrLondon
Oct 17, 2017Aspirant
6.7.5
cant think of any reason, just went to login and found i couldnt,
can still see the contents of the drive vis the finder.
Oct 17, 2017Guru - Experienced User
Does https://nas-ip-address/fwbroker respond? Use the real NAS IP address of course.
- MrLondonOct 17, 2017Aspirant
could connect and posted image of result.
- StephenBOct 17, 2017Guru - Experienced User
Good.
Usually this problem is related to an app incompatibility - do you know what apps you had installed?
There are some fixes to get the admin ui back in 6.8.1, but there are some additional fixes in 6.9.0-RC1.
I suggest trying to manually install 6.9.0-RC1 using this interface, but if you are uncomfortable with beta firmware you can try 6.8.1 instead.
only app installed and running is Transmission.
now installing 6.8.1
will post results
