ash1
Apr 06, 2013Aspirant
Can't connect to NVX..a little desperate!!
Ever since i rearranged some of my network gear, the readynas doesn't allow us to connect to it. i also can't get to it in frontview, even though we are using the correct ip address. i just have...
Apr 06, 2013Guru - Experienced User
The router should have 5 ports on the back (1 yellow). The yellow one would be the WAN port. If you are trying to use a router as a switch it is important not to plug into the WAN port.
If you can reach the NAS in direct connect mode you can reconfigure the ethernet so it works on your new network setup.
BTW, what IP address is RAIDar giving you for the NAS? Also, what IP is your Mac?
