ash1
Apr 06, 2013Aspirant
Can't connect to NVX..a little desperate!!
Ever since i rearranged some of my network gear, the readynas doesn't allow us to connect to it. i also can't get to it in frontview, even though we are using the correct ip address. i just have...
ash1
thanks again..
your understanding of this is obviously pretty good!
yes the yellow port was being utilised.
could that have disrupted the nas (by removing the the router device)?
btw, in the future, if i was going to used the wr3500 as a switch again, do i just use the power input and the four ethernet ports?
on the front screen of the nas and WakeOnLan it says the nas is 192.168.5.6.
in sys. prefs.>network the main window says:
"Ethernet is active and has ip address 192.168.1.123"
also, "using dhcp",
"subnet mask 255.255.255.0",
"router (which i think in this case is the modem?) 192.168.1.1
i will try to get a long cable to the nas, otherwise i'll retrieve it (pain) and bring it closer the the imac.
when i get it connected, what do i need to do to reconfigure the ethernet so it works moving forward?
cheers, tony
also, "using dhcp",
cheers, tony
