ash1
Apr 06, 2013Aspirant
Can't connect to NVX..a little desperate!!
Ever since i rearranged some of my network gear, the readynas doesn't allow us to connect to it. i also can't get to it in frontview, even though we are using the correct ip address. i just have...
mdgm-ntgr
Apr 06, 2013NETGEAR Employee Retired
An OS Re-install resets the admin password to default (for your device it is 'netgear1'). It also resets some network settings. Most of your configuration will remain intact.
The procedure is here: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
Since things were working fine till you rearranged some network gear this will most likely resolve the problem as it will reset the network settings so that your NAS will pickup an I.P. address from your router.
