ash1
Apr 06, 2013Aspirant
Can't connect to NVX..a little desperate!!
Ever since i rearranged some of my network gear, the readynas doesn't allow us to connect to it. i also can't get to it in frontview, even though we are using the correct ip address. i just have...
ash1
Apr 07, 2013Aspirant
i cannot express how thankful i am for the support you have given us here,
with a little sweat at this end all is working properly again so far..
i did the reinstall which brought the 192.168.168.168 failover.
still couldn't connect at that stage, so restarted everything in the device chain.
the nas reset to another ip address which raidar found.
we can connect from the sidebar to 'afp' and 'cifs' as well.
and to top it all off, timemachine seems fine on my machine... will check others later.
you are a gem!
many thanks!
you are a gem!
many thanks!
