ash1's avatar
ash1
Can't connect to NVX..a little desperate!!
Ever since i rearranged some of my network gear, the readynas doesn't allow us to connect to it.
i also can't get to it in frontview, even though we are using the correct ip address.
i just have a simple setup now..modem connected to switch which is connected to our machines.
i recently retired what seemed to be a faulty netgear WR3500 router in the setup. it had only previously been
used as a switch.
it was seemingly faulty, so we retired it.
we use the NVX for general storage as well as Apple Timemachine.
can anyone help me out?
  • oh yeah,
    as i said before the device we recently retired was the netgear WNR3500 router.
    in the end it was being used as a switch only.
    but stephenb pointed out that it should never have had the WAN port used, if that was the case.
    the modem was connected to that port, and three devices were connected to the other ports.
    saying that, could that have potentially caused trouble..speed issues, etc?
  • StephenB's avatar
    Yes. If the WAN port was used with the normal router config you would have seen more connectivity issues than speed problems. For instance, a device connected to the WNR might be able to reach other devices on the network, but they would not be able to reach it.
    Though routing through the WAN port is slower than switching, so there would be some loss there also.
    If the WAN port was connected to a local device (not the upstream router/switch) then that device probably wouldn't have any connectivity.
    Some Netgear routers can be configured as access points. In that scenario, you would get full connectivity but you would see a speed loss between the WAN port and the others. I am not seeing that option in the WNR3500 manual though.
  • thanks for the info. we shouldn't have to use the WNR again in our network anyway, so hopefully it's a goner..
    so far everything appears to running faster post WNR.
    one thing we have had trouble with, from time to time, while the WNR was part of the network (WAN port used), was that our TimeMachine backups would fail. the TM backups are all domiciled on the NVX.
    each of the 5 computers/backups in the network have suffered at one time or the other,
    but only one at a time.
    when it happens, there appears to be a verification error from TimeMachine and it won't connect to the backups on the NAS.
    we've had the WNR ever since the NAS, so i'm keeping fingers crossed that it was the WNR that has caused the headaches.
    cheers
ProSupport for Business
