annekrijn
Jan 09, 2015Aspirant
Can't connect to web admin panel on ReadyNAS RN102 #24506517
Hi there, After running beautifully for about a year, my RN102 won't let me connect to its admin panel anymore. I've never experienced problems before, I would just go to the local IP address and i...
- Jul 13, 2016
I reviewed the case and see that the issue was due to a problem with uninstalling apps, which was a known issue in 6.2. I'm marking this as solved.
Peder
Mar 13, 2016Aspirant
If you are using IE11.
Select the gear-icon in the upper right corner and choose compatibillity view settings. Add your readynas IP to the list. Reload. Ignore sertificate warning. You should be in.
