annekrijn
Jan 09, 2015Aspirant
Can't connect to web admin panel on ReadyNAS RN102 #24506517
Hi there, After running beautifully for about a year, my RN102 won't let me connect to its admin panel anymore. I've never experienced problems before, I would just go to the local IP address and i...
- Jul 13, 2016
I reviewed the case and see that the issue was due to a problem with uninstalling apps, which was a known issue in 6.2. I'm marking this as solved.
Peder
Mar 13, 2016Aspirant
If you are using IE11.
Select the gear-icon in the upper right corner and choose compatibillity view settings. Add your readynas IP to the list. Reload. Ignore sertificate warning. You should be in.
BrianL2
Mar 13, 2016NETGEAR Employee Retired
Hi Peder,
Welcome to the community!
Thank you for sharing in the community. Other members will find this suggestion useful incase they encounter the same problem. We hope that this won't be the last time that you post an idea, suggestion or question :)
Kind regards,
BrianL
NETGEAR Community
