annekrijn
Jan 09, 2015Aspirant
Can't connect to web admin panel on ReadyNAS RN102 #24506517
Hi there, After running beautifully for about a year, my RN102 won't let me connect to its admin panel anymore. I've never experienced problems before, I would just go to the local IP address and i...
- Jul 13, 2016
I reviewed the case and see that the issue was due to a problem with uninstalling apps, which was a known issue in 6.2. I'm marking this as solved.
Bell98
Jan 20, 2015Guide
My problem too - deleting ReadyNas Surveillance trashed the unit - now looking at a Factory Reset with full delete - I don't want that either. See "Uninstalling RN Surveillance crashed - can't access Admin"
[quote="annekrijn"]
- before it 'broke', I was messing with some external apps on it, BarracudaDrive and others. Decided to delete them all, because I didn't get it to work properly. Deleting the apps hung the NAS, I pulled the power and rebooted it.
- I also reinstalled the OS using the Reboot sequence with the reset button. After reinstall, connecting to shares in Win7 again works well, but no luck on the admin panel.
[quote="annekrijn"]
