BJB
Aug 26, 2014Aspirant
Can't copy or delete a folder/file
Greetings. I was just going to ignore this but I am curious. I keep my iTunes library on my NAS and had a downloaded audiobook which is a .m4b file get stuck in the download folder. In the past...
BJB
Aug 27, 2014Aspirant
Thanks, will try deleting via the GUI tonight. I did reboot the PC's (well had no choice after explorer crashed) which made no difference.
I was current on firmware the last time I checked but offsite so not sure of the number right now. I only use public release firmware if that helps.
Thanks again,
BJB
Thanks again,
BJB
