BJB
Aug 26, 2014Aspirant
Can't copy or delete a folder/file
Greetings. I was just going to ignore this but I am curious. I keep my iTunes library on my NAS and had a downloaded audiobook which is a .m4b file get stuck in the download folder. In the past...
Aug 29, 2014Guru - Experienced User
Huh?
mdgm wrote: rgrenader you have an older device which doesn't have this feature in the GUI interface. Your NAS won't get this feature though you could try some add-ons if you need this.
http://nasname/shares lets you delete files and folders on a duo v1 (as long as http access is enabled for the share).
