BJB
Aug 26, 2014Aspirant
Can't copy or delete a folder/file
Greetings. I was just going to ignore this but I am curious. I keep my iTunes library on my NAS and had a downloaded audiobook which is a .m4b file get stuck in the download folder. In the past...
Aug 30, 2014Guru - Experienced User
What you see depends on whether webdav is enabled (or not).
mdgm wrote: Though I can't see the option to rename or delete files using that.
Without webdav, when you navigate into a share there is checkbox next to each file or folder. Along the top there are controls for copy, paste, delete, rename, new file, new directory, upload, and a couple of others.
