siigna
May 06, 2015NETGEAR Employee Retired
Can't create backup job involving USB drive on 6.2.3/6.2.4
Some have run into an unfortunate bug in the 6.2.3/6.2.4 releases of ReadyNAS OS regarding backup jobs involving a USB device. Attempting to configure a backup job from or to a USB device wil...
mdgm-ntgr
May 31, 2015NETGEAR Employee Retired
From the Release Notes:
If you wish to remove a USB storage device, you should follow the safe removal procedure of first unmounting before removing the USB device. If these steps are not followed then you may develop errors on the file system on the USB device.
