siigna
May 06, 2015NETGEAR Employee Retired
Can't create backup job involving USB drive on 6.2.3/6.2.4
Some have run into an unfortunate bug in the 6.2.3/6.2.4 releases of ReadyNAS OS regarding backup jobs involving a USB device. Attempting to configure a backup job from or to a USB device wil...
nikoweb
Jun 08, 2015Aspirant
Good morning, I had the same problem, I can not use the advanced options "remove deleted files on the target" This is useful for creating a bachup exactly equal to readynas. If you do not use when I delete a file on readynas remains on target. For example, if I move a few files of a new cartel, the destination will find both the original files you copy them to the new folder.
Does anyone know how to solve the problem? Thank you.
