TonyM1
Mar 15, 2014Aspirant
Can't delete volume C
Hardware: RNDU4, 4x3Tb drives Firmware: 3.2.26 Configuration: RAID 5, all 4 disks in the volume C I want to create separate volumes on the drive for different purposes, still spreading the volu...
vandermerwe
Mar 15, 2014Master
If it's not letting you delete existing volume, why not just factory default and set the NAS up from scratch. You're going to wipe the disks anyway by deleting volumes.
