TonyM1
Mar 15, 2014Aspirant
Can't delete volume C
Hardware: RNDU4, 4x3Tb drives Firmware: 3.2.26 Configuration: RAID 5, all 4 disks in the volume C I want to create separate volumes on the drive for different purposes, still spreading the volu...
TonyM1
I'm using Firefox 27.0.1
Yes, when doing the factory reset I go into RAIDar 4.3.8 to initiate the configuration, but that only allows me to select the RAID level. It doesn't give me the opportunity to change which volumes get created.
As this is a clean install, I'm open to doing a factory reboot, despite that it takes FOREVER to resync the last drive.
