bheinz874
Oct 13, 2017Aspirant
Can't enable SMB on RN102 running 6.8.1
I cannot enable SMB in the system settings on my RN102. I can access the shares with AFP (MacOS) and NFS (Debian Linux) clients, but not SMB (Windows 10). When I go to Settings -> Services, click on ...
bheinz874
I found some information by running journalctl -xe:
Oct 13 19:15:41 Heinz-Home-NAS systemd[1]: Starting Samba SMB Daemon... -- Subject: Unit smb.service has begun start-up -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit smb.service has begun starting up. Oct 13 19:15:45 Heinz-Home-NAS systemd[1]: smb.service: Main process exited, code=exited, status=1/FAILURE Oct 13 19:15:45 Heinz-Home-NAS systemd[1]: Failed to start Samba SMB Daemon. -- Subject: Unit smb.service has failed -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit smb.service has failed. -- -- The result is failed. Oct 13 19:15:45 Heinz-Home-NAS wsdd2[6358]: Terminated received. Oct 13 19:15:45 Heinz-Home-NAS wsdd2[6358]: Terminated received. Oct 13 19:15:45 Heinz-Home-NAS wsdd2[6358]: cannot read netbios name from testparm Oct 13 19:15:45 Heinz-Home-NAS systemd[1]: smb.service: Unit entered failed state. Oct 13 19:15:45 Heinz-Home-NAS wsdd2[6358]: cannot read netbios name from testparm Oct 13 19:15:45 Heinz-Home-NAS systemd[1]: smb.service: Failed with result 'exit-code'. Oct 13 19:15:45 Heinz-Home-NAS systemd[1]: Stopping WSD/LLMNR Discovery/Name Service Daemon... -- Subject: Unit wsdd2.service has begun shutting down -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
Hopefully that makes sense to someone.
- StephenBOct 16, 2017Guru - Experienced User
What is the system's hostname?
- bheinz874Oct 16, 2017Aspirant
Heinz-Home-NAS is the hostname. I tried changing it to just NAS, still won't start. I can turn on and off everything else, just SMB is giving me trouble.
- StephenBOct 17, 2017Guru - Experienced User
Can you look in the OS partition and see if there are files that are owned by guest:guest?
Some (badly written) app installs can do this, and it has created similar symptoms for some folks.
