bheinz874
Oct 13, 2017Aspirant
Can't enable SMB on RN102 running 6.8.1
I cannot enable SMB in the system settings on my RN102. I can access the shares with AFP (MacOS) and NFS (Debian Linux) clients, but not SMB (Windows 10). When I go to Settings -> Services, click on ...
Oct 16, 2017Guru - Experienced User
What is the system's hostname?
bheinz874
Oct 16, 2017Aspirant
Heinz-Home-NAS is the hostname. I tried changing it to just NAS, still won't start. I can turn on and off everything else, just SMB is giving me trouble.
- StephenBOct 17, 2017Guru - Experienced User
Can you look in the OS partition and see if there are files that are owned by guest:guest?
Some (badly written) app installs can do this, and it has created similar symptoms for some folks.
- bheinz874Oct 17, 2017Aspirant
Several folders are owned by guest, some by root:
root@Heinz-Home-NAS:/# ls -l total 80 drwxrwxr-x 1 guest guest 140 Oct 14 16:31 apps drwxr-xr-x 2 root root 4096 Oct 13 17:49 bin drwxr-xr-x 2 root root 4096 Jun 17 2012 boot -rwxrwxrwx 1 guest guest 0 Oct 31 2014 cp_check_md5sums.sh drwxrwxrwx 1 guest guest 254 Mar 31 2017 data drwxr-xr-x 14 root root 3360 Oct 13 17:50 dev drwxr-xr-x 88 root root 4096 Oct 17 05:52 etc drwxr-xr-x 7 root root 4096 Oct 13 17:50 frontview -rwxrwxrwx 1 guest guest 0 Aug 23 2015 ftp_ban.tbl drwxr-xr-x 1 guest guest 32 Jan 12 2015 home lrwxrwxrwx 1 guest guest 5 Dec 17 2013 homes -> /home drwxr-xr-x 15 root root 4096 Oct 13 17:49 lib drwxrwxrwx 2 guest guest 16384 Oct 30 2013 lost+found drwxr-xr-x 2 root root 4096 Nov 17 2012 media drwxr-xr-x 2 root root 4096 Apr 29 2016 mnt drwxr-xr-x 9 root root 4096 Jul 28 12:15 opt dr-xr-xr-x 177 root root 0 Dec 31 1969 proc drwx------ 3 root root 4096 Oct 13 17:49 root drwxrwxr-x 27 root admin 940 Oct 17 05:52 run drwxr-xr-x 2 root root 4096 Oct 13 17:49 sbin drwxrwxrwx 2 guest guest 4096 Jun 10 2012 selinux drwxr-xr-x 2 root root 4096 Nov 17 2012 srv dr-xr-xr-x 11 root root 0 Oct 13 17:50 sys drwxrwxrwt 7 root root 4096 Oct 17 05:52 tmp drwxr-xr-x 10 root root 4096 Jul 28 12:15 usr drwxr-xr-x 18 root root 4096 Oct 13 17:49 var root@Heinz-Home-NAS:/#
That's the issue then. Mine looks like this:
drwxr-xr-x 1 root root 1338 Sep 26 07:39 bin drwxr-xr-x 1 root root 0 May 21 2012 boot drwxr-xr-x 1 root root 412 Sep 21 08:53 data drwxr-xr-x 16 root root 3340 Sep 26 07:40 dev drwxr-xr-x 1 root root 2614 Sep 26 14:27 etc drwxr-xr-x 1 root root 58 Sep 26 07:39 frontview -rw-r--r-- 1 root root 0 Nov 9 2016 ftp_ban.tbl drwxr-xr-x 1 admin admin 10 Jan 26 2017 home lrwxrwxrwx 1 root root 5 Nov 22 2016 homes -> /home drwxr-xr-x 1 root root 462 Sep 26 07:39 lib drwxr-xr-x 1 root root 40 Sep 26 07:39 lib64 drwxr-xr-x 1 root root 32 Jun 4 2012 media drwxr-xr-x 1 root root 0 Jan 25 2016 mnt drwxr-xr-x 1 root root 98 Jul 28 13:14 opt dr-xr-xr-x 223 root root 0 Sep 26 07:39 proc drwx------ 1 root root 64 Sep 26 07:39 root drwxrwxr-x 25 root admin 800 Oct 9 06:22 run drwxr-xr-x 1 root root 2428 Sep 26 07:39 sbin drwxr-xr-x 1 root root 0 Jun 4 2012 srv dr-xr-xr-x 12 root root 0 Sep 26 07:39 sys drwxrwxrwt 1 root root 140 Oct 17 07:17 tmp drwxr-xr-x 1 root root 70 Jul 28 13:14 usr drwxr-xr-x 1 root root 146 Sep 26 07:39 var
This can get messy, since of course the ownership is likely wrong in the subfolders too.
