lezardsouffle2
Oct 13, 2021Aspirant
Can't enable SMB on RN428
I recently switched my RN428 from a RAID 6 to a RAID 0 (wiping all the data). After I did, the device wouldn't let me create my shared folders again, so I did a factory reset. I was able to create ...
- Oct 13, 2021
lezardsouffle2 wrote:
I selected "Enable" "Globally" and it seems to have turned on SMB now (I can now see the NAS in Windows), but I don't really know what I've done by saying "Enable" "Globally".
Globably just means "these settings are for all shares". The alternative is to configure the SMB transport for each share in its share settings.
Not sure how to read them really (below), but it looks like the system didn't like the fact that I didn't select anything for the SMB3 Transport Encryption
Required - Always encrypt the network transport (denying access if the client can't do that).
Desired - Encrypt the network when possible (if the client supports it), but allow access if the client doesn't support encrypted transport.
Enabled - Allow the network transport to be encrypted (so it will only be encrypted if the client requires that).
Disabled - never encrypt the network transport (denying access if the client requires it).
Oct 13, 2021Guru - Experienced User
What firmware are you running?
lezardsouffle2
6.10.5 Hotfix 1
