kristianherlufs
Jan 05, 2013Aspirant
Can't find path for shares
Hi Everyone I've had my ReadyNAS Duo v2 for four months now, and everything has worked perfectly until now. But after I disconnected and connected the power to my NAS yesterday I can no longer gain...
evan2
Jan 07, 2013NETGEAR Expert
I see your logs, the device's partition table lost, please contact technical support, let them remote control your device to recover the partition table.
Disk /dev/sda doesn't contain a valid partition table
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/md0 doesn't contain a valid partition table
Disk /dev/md1 doesn't contain a valid partition table
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
256 heads, 63 sectors/track, 121126 cylinders, total 1953525168 sectors
Device Boot Start End Blocks Id System
/dev/sdb1 1 1953525167 976762583+ ee GPT
Disk /dev/md0: 4293 MB, 4293906432 bytes
2 heads, 4 sectors/track, 1048317 cylinders, total 8386536 sectors
Disk /dev/md1: 536 MB, 536858624 bytes
2 heads, 4 sectors/track, 131069 cylinders, total 1048552 sectors
