dsm1212
Jan 31, 2015Apprentice
Can't get itunes to work on 6.2.2
I've enabled itunes as a service. Then gone into a share under network settings enabled itunes. I see the conf file looks correct (/data/Music is listed). The forked-daapd.log showed a bunch of lines ...
mdgm-ntgr
Jan 31, 2015NETGEAR Employee Retired
If you download the logs do you see any clues in systemd-journal.log?
