dsm1212
Jan 31, 2015Apprentice
Can't get itunes to work on 6.2.2
I've enabled itunes as a service. Then gone into a share under network settings enabled itunes. I see the conf file looks correct (/data/Music is listed). The forked-daapd.log showed a bunch of lines ...
dsm1212
Feb 01, 2015Apprentice
On the full scan I see some errors about bad playlists, but when I cut back to the share with a couple of files I see nothing obvious. There are these two errors that I think probably happened the one time I got an album to display, but I'm not sure:
Feb 01 00:48:49 warehouse6 forked-daapd[2907]: scan: Bulk library scan completed in 1 sec
Feb 01 00:49:49 warehouse6 forked-daapd[2907]: daap: Could not start query
Feb 01 00:49:49 warehouse6 forked-daapd[2907]: cache: Error building DAAP reply for query: /databases/1/containers/8/items?delta=0&meta=dmap.itemid,dmap.containeritemid
Feb 01 00:49:49 warehouse6 forked-daapd[2907]: cache: Error building DAAP reply for query: /databases/1/containers/10/items?delta=0&meta=dmap.itemid,dmap.containeritemid
steve
steve
