dsm1212
Jan 31, 2015Apprentice
Can't get itunes to work on 6.2.2
I've enabled itunes as a service. Then gone into a share under network settings enabled itunes. I see the conf file looks correct (/data/Music is listed). The forked-daapd.log showed a bunch of lines ...
mdgm-ntgr
Feb 01, 2015NETGEAR Employee Retired
I guess those log entries must have been pruned from the logs that you sent. If you are willing to try 6.2.3 beta, do a fresh full scan and then send in a fresh set of logs that would be great.
