dsm1212
Jan 31, 2015Apprentice
Can't get itunes to work on 6.2.2
I've enabled itunes as a service. Then gone into a share under network settings enabled itunes. I see the conf file looks correct (/data/Music is listed). The forked-daapd.log showed a bunch of lines ...
dsm1212
Feb 02, 2015Apprentice
Another data point: I had a windows box running an old version of itunes. The small share I had worked! itunes prompted me to upgrade to itunes 12.1 so I did it and it stopped working. So I think the issue is in fact that something has recently changed in itunes. Can you turn this into a bug submission? It's easy to repro. Install 12.1 itunes and it stops working.
Seems like a known issue with forked-daapd:
https://github.com/ejurgensen/forked-daapd/issues/100
