dsm1212
Jan 31, 2015Apprentice
Can't get itunes to work on 6.2.2
I've enabled itunes as a service. Then gone into a share under network settings enabled itunes. I see the conf file looks correct (/data/Music is listed). The forked-daapd.log showed a bunch of lines ...
mdgm-ntgr
Feb 02, 2015NETGEAR Employee Retired
I have notified product engineering about this issue. There is likely not anything we can do until/unless the developers of forked-daapd come up with a solution.
Considering Firefly on legacy ReadyNAS still works I would think a fix should be possible.
