dsm1212
Jan 31, 2015Apprentice
Can't get itunes to work on 6.2.2
I've enabled itunes as a service. Then gone into a share under network settings enabled itunes. I see the conf file looks correct (/data/Music is listed). The forked-daapd.log showed a bunch of lines ...
dsm1212
Feb 03, 2015Apprentice
A guy maintaining a fork of forked-daapd at the link I posted above is hot on the trail. He posted a work-around code change already. It appears forked-daapd may not be handling group based requests correctly.
steve
steve
