dsm1212
Jan 31, 2015Apprentice
Can't get itunes to work on 6.2.2
I've enabled itunes as a service. Then gone into a share under network settings enabled itunes. I see the conf file looks correct (/data/Music is listed). The forked-daapd.log showed a bunch of lines ...
Feb 04, 2015Guru - Experienced User
I'd be very surprised if Apple changes iTunes to resolve a forked-daapd issue. From their point of view, iTunes is their's and they'd just as soon reverse-engineered linux iTunes servers didn't exist.
Marcello29 wrote: So if i understand i must wait readynas upgrade of Forked-DAAPD.
So I think you will need to wait for a forked-daapd fix.
