dsm1212
Jan 31, 2015Apprentice
Can't get itunes to work on 6.2.2
I've enabled itunes as a service. Then gone into a share under network settings enabled itunes. I see the conf file looks correct (/data/Music is listed). The forked-daapd.log showed a bunch of lines ...
mdgm-ntgr
Feb 13, 2015NETGEAR Employee Retired
When you download the logs you can filter systemd-journal.log for forked-daapd. Is that what you mean?
Or do you mean via SSH?:
# journalctl -a | grep forked-daapd
