ToolBar's avatar
ToolBar
Can't get WebDAV to work properly
On a ReadyNAS Pro 2 with RAIDiator 4.2.28 I followed the instruction here (p. 41) to activate WebDAV. I registered a ddns domain name on NO-IP.Com. I then set my router to use this ddns domain name. ...
  • JennC's avatar
    Feb 09, 2016
    Hello ToolBar,
    You can only set HTTP/S to get redirected to a specific share, I see no option for selecting only the ones with WebDav enabled.
    See this article's second part "Set Up Your Router for Remote Access" where it shows how to access the shares via WebDav. Ignore the first part that shows steps how to enable it on ReadyNAS OS6, you are using ReadyNAS OS4.
ProSupport for Business
