gmarconi
Oct 05, 2015Aspirant
can't negotiate 10gigabit connection
I am unable to make the readynas 4200 negotiate with the netgear prosafe XS708E at 10gigabit. With cat5e and cat6 cable in the status of the interface I only see: Online / Mbit / Half-Duplex ...
Oct 05, 2015Guru - Experienced User
You are using one of the 10 gbe ports? With the 10 gbe option, the NAS should have 4 interfaces.
gmarconi
Oct 11, 2015Aspirant
hi StephenB
My ReadyNAS 4200 has only 2 100/1000/10gbe nic.
The strange thing is that when I connect it to a 1000gbit switch it says STATUS: Online / 1 Gbit / Full-Duplex
While when I connect to the 10gbe switch (Prosafe XS708E) it says STATUS: Online / Mbit / Half-Duplex
The Speed/Duplex mode shows me only 100mbit full duplex / 100mbit half duplex.
The Show Erros tells only 40 trasmitted packet and all others counters are 0.
From the Switch counters it seems all regular (receiced and trasmitted counter increasing) and I don't see any CRC Error Packets.
Giaco
- StephenBOct 14, 2015Guru - Experienced User
This is running 4.2.x firmware?
If so, the models should be
ReadyNAS 4200 with 2 x Gigabit Network
RN12T1210 (12 x 1TB)
RN12T1220 (12 x 2TB)ReadyNAS 4200 with 2 x Gigabit + 2 x 10GbE (CX4)
RN12G0620 (6 x 2TB)
RN12G1220 (12 x 2TB)ReadyNAS 4200 with 2 x Gigabit + 2 x 10GbE (SFP+)
RN12S0620 (6 x 2TB)
RN12S1220 (12 x 2TB)2 x 10GbE add-on card
RN12T2CX4-100WWS (CX4)
RN12T2SFP-100WWS (SFP+)Can you identify which NAS part number you have from the above (and which 10 GbE add-on card you are using?)
- gmarconiOct 15, 2015Aspirant
4.2.27 firmware and after your explanation i think to have the ReadyNAS 4200 with 2 x Gigabit Network...
the Seller told me 2 x 10GbE....
Then I was trying to make a 10GbE link on a Gigabit nic....
So:
I tried to plug in an Intel Converged Network Server Adapter 10GB (copper) in the pci express slot.
Now the led in the prosafe switch shows the right color for the 10GbE link, but the Nas doesn't see the third adapter.
Giacomo
- StephenBOct 15, 2015Guru - Experienced User
gmarconi wrote:
So:
I am thinking there are drivers needed. Perhaps someone from Netgear can give some guidance.
