TNorthcutt
Sep 27, 2014Aspirant
Can't resolve ERR: BAD FIRMWARE on NV+
My little 2007 NV+ is finally giving me fits after years of good use. Here's the chronology. I was at work the entire time and did nothing manually. At 7:08 AM the NAS alerted me of an SATA res...
mdgm-ntgr
Sep 27, 2014NETGEAR Employee Retired
Can you power down, remove your disks (label order), connect your disks to your PC and test them e.g. using SeaTools to test SeaGate disks? It's possible you may have more than one bad disk.
A factory default with just a spare disk (must not be from your array) is a good way to help isolate where the problem is.
