TNorthcutt
Sep 27, 2014Aspirant
Can't resolve ERR: BAD FIRMWARE on NV+
My little 2007 NV+ is finally giving me fits after years of good use. Here's the chronology. I was at work the entire time and did nothing manually. At 7:08 AM the NAS alerted me of an SATA res...
mdgm-ntgr
Sep 28, 2014NETGEAR Employee Retired
Either way you may wish to consider an initial diagnostics data recovery contract if your data is important to you.
Trying to fix the problem yourself may just make things worse.
Checking the disks using non-destructive tests should be fine though.
Do note that one of your disks may appear to your computer to be unformatted. It is not. Do not let your computer wipe it.
